ONEX #54 Web Site
Date:  2-17-2013
Manual Reference:  F09, L02
Brief Description:  Firewall cowling attach hinges
Drilled the cowling attach hinges, F09-03/04.
Since I'm building a tri-gear, not all the F09-03 hinge rivet holes get drilled. The steering pulleys, L02-14 R/L, get attached over the hinge with AN3 bolts. Because I moved my rudder pedals back about 6", the geometry of where the steering cable penetrates the firewall may change slightly because of the change in the pivot point of the cable adjusters C03-24 on dwg C01 view H-H. The end of the cable adjuster that attaches to the steering cable will probably move down slightly. I need to install the adjusters to get the correct dimension. This means basically doing the rudder control installation IAW the General Rigging Order for the rudder control system on sheet C01.
Cowling attach hinges
